Discuss Electrical help in the UK Electrical Forum area at ElectriciansForums.net
You
I have 3 wires coming to my electrical pannel i have 2 hots a uncoated silver wire n another wire. None of which r hooked up to pannel yet. I know the 2 hots go to main breaker n then the silver wire goes to ground but there is no common. White wire. Now i have the box wired to where the bar the common wire usually goes to i have a jumper connecting to the ground i can send pic i need to know b4 i hook the powrr to box if this is right. And when wiring up breakers where does the white wire go. Normally there should b 2 hots coming in a white and a silver ground. But there is no white.
You
My friend the silver wire is your white wire or neutral so it hooks to the neutral bar the only wire your missing is your equipment ground and the 2 hots go to the main breaker. Only one wire per lug. I also have to agree with norcal, that panel has seen its better days and is a hazard.
Reply to Electrical help in the UK Electrical Forum area at ElectriciansForums.net
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
I had done this about 30 years ago, and, IIRC, it was a series of boxes, Romex coming in, and Romex coming out, one in, one out, each box, except...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
