Discuss emergency light testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone.
I have an emergency light test coming up. I have never carried one out before. Is it as simple as:
1. Checking there is a key switch/isolator
2. Making sure all emergencies are working correctly
3. Making sure the batteries are up to scratch by them staying illuminated for the 3 hours?
Any advice will be great fully received.
Well first step is a good read of the bs5266....but the paperwork is just as important...logging and numbering every fitting, with location and type. Covering log book for customer and maintenance tests, of visual, weekly 5 mins tests, 6 monthly 30 min tests and annually 3 hour duration discharge test...you will need to have spares onboard, for lamp and battery changes, there is no "i`ll come back next week to change the tube", it needs to be done asap....a survey before testing is always important
Can be a very serious game to play.....if for any reason it can be prove that lack of em lighting, resulted in people being trapped in a building...the HS could have a field day....always keep log book and paper work up to date
erm no from memory you are seeing if there is a compliant system. if the building is massive and has one emergency light would you say that was fine? do you have to original design documents?
No they won't be there I wouldn't imagine. And I would imagine the system is old so could well need a few adding.
Do either of you know of anywhere I can download a decent cert template?
Well it is valid point, if there is not enough lighting to comply, you will need to re design/upgrade the system....as to certs, used your scam jobbies,
Is the testing side basically switching the key switch and making visually checking all fittings are up to standard?
Unfortunately, not every system includes a keyswitch to mimic a power loss. I was working in a nursery last week and had to go in at the weekend as the circuits had to be switched off to do a visual check :-(
Reply to emergency light testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi all, I am an electrician working for a OEM machinery manufacturer based in Germany, we are the local hub that is now taking over the...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
