Discuss Emergency Stop Button for a 3 Phase 3HP Motor Help. in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
Long story short, I am building a plastic shredder with a 3 phase 3 HP motor. I am using this switch to control forward and backwards: https://goo.gl/k8zSxA (amazon). I need a switch or button that can cut power to the device. It does not need to stop immediately. I am not using a Contactor or motor controller. Any help would be much appreciated.
Thanks.
Just stick a stop button in series with the supply, that said, why not a contactor? what about overload protection?
need to be careful here. a different set of regs. and safety standards apply, outside the scope of BS7671. darkwood is your best advisor here.
Good point, I never realised he was a Yank
There's a worrying statement 'What do you mean by overload protection '.
You Deffo need a contactor with overload protection rated at same as motor on the plate,
I would wire the control circuit in series through the stop button and through to enable that coil.
Yplan
BS EN 60204
7.3.1 General
Protection of motors against overheating shall be provided for each motor rated at more than 0,5 kW.
You should have an equivalent reg.
Don't think it is quite the same in the States, it is required but the parameters are different.
Welcome to the Forum, is this a project at your Academy?
The Forum is based around UK regulations and even though you may be USA based I would believe there exists strict regulation and rules surrounding the designing and building of control systems for machinery.
Anyone who is competent and qualified to design and install such systems would not be asking the basic of basic questions on a Forum and as a Forum it is our duty to offer safe advice. It is therefore my only option to advise you to contract in a competent qualified person to design and build these controls for you, this is for your own safety and that of any user.
It is for the above reasons that I am closing this thread, this is not something to do as a DIY project without some indepth knowledge of the relevant standards and risks associated.
If this is indeed a project for your Academy them you should discuss this with your tutor and ask for their assistance, it is to be noted that (s)he too would need to be fully compliant and knowledged in the relevant regulations that surround this 'project'.
Please PM me if you have any queries to why your thread has been closed or to add any supporting information which may allow us to reopen the thread.
Re' Darkwood.
Reply to Emergency Stop Button for a 3 Phase 3HP Motor Help. in the UK Electrical Forum area at ElectriciansForums.net
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
