swifters
Regards an MCS application do you need to own the two documents or only have access to them? How are people accessing them if so? Thanks.
P.s. Do the brackets, rails and inverters you use now have to be MCS marked? My assessor stated they did. I was under the impression that the inverter had to be G83 approved and that was it. I have seen a document detailing all the solar panels that are MCS approved but never one for inverters and fixings?
Suppose the paper you use to print off the handover pack will have to be MCS approved next.
