I
infaddict
Hi guys, happy new year to you all - I hope the hangovers have recovered by now! I'm also hoping you pro's out there can give me some advice. I've just moved into a brand new house (4 bed bungalow) and the driveway and garden are pitch black at night, so I'm looking to install 1 or 2 PIR security lights for security and also so I can see when arriving home at night or popping out to the garage at night.
Installation in my external garage might be easier because it means I don't need to crawl about the loft space. However, the garage is about 25 metres up a driveway so I'd need to make sure my light could light the whole driveway. I'd like some advice on :
Here's the current situation (maybe too much info but might help!) :
House
Main consumer unit with 2xRCD
Main switch 100A
Garage MCB 16A
Lighting / Alarm MCB 6A
Lighting / Door Bell MCB 6A
Sockets MCB 32A
Sockets MCB 32A
plus others for smoke alarm, oven, heating, grid switch and hob.
(why I have 2 MCB's for lights and sockets I'm not sure, possibly to split the load?)
Garage
2 switch consumer unit in garage
Main switch 63A
Lighting MCB 6A (only 1 ceiling light)
Socket MCB 16A (only 1 double socket)
Any advice on my 3 points above is very much appreciated. Thanks in advance!
- whether a competent DIY'er could install these lights without breaking any regs - do these come under part P as they are external?
- wiring the lights e.g. wiring into lighting circuit or socket circuit etc.
- opinions on halogen lights vs newer LED lights. Seems hard to find comparison on lumens emitted. I'm worried that whilst the LED's might be cheaper to run, they won't be bright enough for my long drive way. Saying as the lights will only be on for 5-10 seconds, cost isn't my big worry.
House
Main switch 100A
Garage MCB 16A
Sockets MCB 32A
Sockets MCB 32A
Garage
Main switch 63A
