Discuss factory rewire help in the UK Electrical Forum area at ElectriciansForums.net
K
kirkbykarl
hi everyone
im currently looking at updating a board in a factory with bs88 fuses in it can anyone reccommend a board and overcurrent protective devices that would be a more suitable replacement?
the out going circuits are ok and up to date
thanks
From his previous posts it looks like he's out of his time, so should know this really.
Why aren't BS88's suitable?
As per usual not enough information given.
At a quick suggestion I would suggest an mccb panel board, either Schneider or Eaton. An Mccb allows you to ascertain which device has operated and can also be adjustable for different ratings.
Does a bs 88 not? just because you can't see it's tripped...it's only removing fuse holders...if labelled correctly.
What if the BS88's have been specked over the use of MCCB's. MCCB's are not through fault rated devices.
A value of short time current rating is available but will be considerably lower than the breaking capacity of the device.
As Rob says without more information it is hard to give a recommendation.
In a particularly heavy environment such as the factory does a lot of welding, or there are a lot of compressors or motors then I would prefer the capacity a BS 88 gives you.
If it is half a dozen sewing machines and a small office loading bay then yes perhaps a MCCB would be better.
Reply to factory rewire help in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, With regards to modelling a multi service distribution board, how would you guys model it in Amtech? I have tried using a TPN...
4K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi all, I have a question regarding the breaking capacity of circuit protective devices. So, the breaking capacity rating of devices in domestic...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
