Discuss Fiesta st500 fan problems in the Auto Electrician Forum area at ElectriciansForums.net
got an mk6 fiesta st500
And radiator fan won’t work
Put power direct to it and it runs fine
Fuses are fine but can’t find relay?
Changed temp sensor
There’s a resistor in bottom of fan shroud this fell apart
Does this stop the fan working or does it control the speed? And it’s really expensive
Help really appreciated
Where did you stick in the power directly to it? Before or after the Resistor pack? Usually the resistor pack just controls fan speed but there is a chance that if the fan is required the speed that the ECU is calling for is goosed because the resistor pack is shot.
Is the car actually getting hot enough to require the fan to be running? Is the car overheating at all because the fan isn’t running?
Also be careful where you are applying 12v power. You may do some damage as some of the wires are lower voltage signal wires .
Forgive me if I am teaching you to suck eggs.
Hi,bud,not really the place for this kind of an issue,but....
The resistor at the bottom,will possibly be the heater blower speed resistor,or other sensor.
The cooling fan,may have a separate relay(s) or may be directly controlled via the ecu or specific ecu.
Have you checked if the fan has it's own fusing? This should be listed,and is the first place to start.
Without much more detail,it is not possible to guess,but sometimes the temperature senders do not only perform one task.
Just had a quick google,for what it's worth,can't see a listed fuse but R5 is the listed relay,on .a version of the Mk6
Reply to Fiesta st500 fan problems in the Auto Electrician Forum area at ElectriciansForums.net
Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM P0691, P0692 for cooling fan control circuit. Tests/Procedures Performed: 1...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
Hi All, Bit of a tricky number. I have recently installed lights / fans /toothbrush chargers and shaver sockets to a bathroom and En-suite. The...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
I have a troublesome problem on my 924. I have replaced the coolant fan 2 times. The fan works this time, but there's a problem. Let me give you...
