Discuss Fire detector options in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
gazdkw82
The fire alarm in the hallway is to sensitive when cooking. It's old and needs changing anyway. It's a mains voltage smoke alarm.
I plan to replace it
and bacon. could also move a way from the kitchen a bit.
Definitely change to optical...
Ionisation sensors use a small radioactive source to detect the invisible smoke particles given off by fast-flaming, clean burning fires such as bedding and clothing, however they can be prone to false alarms from cooking fumes if fitted near kitchens.
Optical sensors use an infra-red beam to detect smoke. They detect smoke from slow, smouldering fires such as electrical fires & are less prone to false alarms from cooking fumes if fitted in the hallway next to kitchen.
Reply to Fire detector options in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
