Discuss Fire sealant for back of distribution board? in the UK Electrical Forum area at ElectriciansForums.net
Any good intumescent sealer will be OK speak to your Scheme or Wholesaler they should be able to adviseAnybody recommend a good intumescent sealant that can be applied directly to PVC cables?
If you're talking about rear cable entry sealing, there is nothing worse than a board sealed with that stuff for installation of future circuits.
Why is it needed?
I haven't carried out any installation work for a few years now so i am a bit out of the loop but i just want to understand what the actual requirements are for this. Say you had a consumer unit mounted on a stud partition wall with the cables coming down in the stud wall and through a nice big knockout in the back of the consumer unit.
Surely this hole would need to be sealed up somehow to prevent a potential fire going up the cavity?
I'm sure there are ways and means of getting around this but as i said i am out of the loop a bit so other than gumming it up with something i wouldn't know what would be the best solution to comply with the various requirements.
Intent of the new regulation
The intent of Regulation 421.1.201 is considered to be, as far as is reasonably practicable, to contain any fire within the enclosure or cabinet and to minimise the escape of flames.
I am genuinely playing devils advocate here but i found this statement above (hope i am allowed to use it, got it off the IET information page).
Surely a fire that happens in a consumer unit has got be contained within it if possible. I understand that the plastic ones would not be able to do that but obviously big holes wouldn't contain it either.
As davesparks said, maybe the solution is to make the holes as tight as possible but i know from past experience and cables coming in from all angles on old installations that this is not always easy.
but it is a moot point if a DB constitutes a fire proof enclosure.
Reply to Fire sealant for back of distribution board? in the UK Electrical Forum area at ElectriciansForums.net
