Discuss Fixings for roof brackets in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
Martin Dawes
I'd be interested to hear what types of fixings people are using to secure their roof brackets.
We have been using 8 x 80 Spax screws but aren't entirely sure what 'industry standard' is.... that is if there is actually a standard.
We also use 8 x 80 Spax screws (with a T40 head). These are actually listed in the K2 roof mounting system catalogue, along with several longer lengths.
MCS3002 states:
4.4.3 External metalwork used for bracketry or mounting frames shall be constructed to
correctly support the imposed static and wind loads, must be adequately
ballasted or fixed into a suitable structural member and shall be adequately
protected from corrosion for a typical life to first maintenance of at least 20 years.
(for example, stainless steel number 1.4301 or 1.4401 to EN 100881 or
galvanised coating on mild steel as specified in EN ISO 14713:1999 for the
appropriate environment, or equivalent)
We were also informed this includes the fixing device. We use A2 Stainless steel coach screws. M8's or M10's in the main. I'm not familiar with the Spax screw to be honest so I can't make a comment either way, just saying what we use.
Reply to Fixings for roof brackets in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
2nd fixing some sockets in an office today and we were talking about high integrity earthing, I've not got a clue what the sockets are going to...
Hi everyone, I really hope someone will be able to help. So last night I tried to change 2 ceiling rose / pendant lights at my mother in laws...
