J
jane1961
I have replaced 7 12v 50w halogen downlights, (removing transformers) and replaced with GU6WW downlights. The new GU10 base lamps have built in drivers so I don't believe I need extra resistance on the circuit. They were fine - but have now started flashing, all at once. An interesting one second slow strobe effect but not ideal in the kitchen.
Every now and then they stay on for three or four seconds but a slight clicking can be heard from the fuse board. I have shut the circuit off.
I had the original downlights fitted by a qualified electrician but found several had burnt out wiring when I removed them. The wholesaler explained I could simply replace them with the new LEDs and have done with the expensive to run so called cool fit halogens.
Can anyone suggest a solution to the flashing 5.4w LEDs?
