Discuss Flat Fire Alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
J
Jon Hodgson
Hi guys just looking for a bit of advice on this or if someone can point me in the right direction of where to find the information I'm after.
I'm quoting for a set of 2 Flats and I'm wondering if I need to interlink the alarms together and if so the best way to do it.
Construction of the flats is timber frame with a mixture of a brick skin exterior and a rendered finish. There's no communal access 1st floor flat is accessible via an exterior staircase. With no communal access there isn't a landlords supply either.
Any help would be great
thanks
Well as they are self contained I was thinking smoke and heat alarms like a standard domestic install would be ok, but its the first set of flats I've been asked to do so I'm a little uncertain
Fire alarms installations need to be designed, installed and certified by a competent person. Not just anyone can do it, totally different to fitting heat/smoke detectors ;)
:thumbsup
Bad terminology on my part there.
So what would be the suggestion here? Get a Fire Alarm system designed for this or that a smoke and heat detector setup would be ok?
Or point me in a direction of where I can get some more information.
From your original post, there is no common or shared fire escape route, so my understanding is that the standard, standalone smoke/fire detection in each property is all that is required.
It looks like a new build, so the design spec must already have been approved - check with the planners/Building Control.
On a related point, remember that the ceiling of the ground floor flat will be creating a fire compartment, so if you are considering downlights........:cheesy:
Regards.
Fortunately there not going to be many and I only fit fire rated since I can get a reasonable deal on them.
The design is being finalised atm permission has been granted but there are still a few bits being sorted on the plans.
Reply to Flat Fire Alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hello, I am trying to find out the requirements/regulations/law which apply to residential multi-storey (3) fire exit/escape lighting. Can...
