Discuss Fluke 199C in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm facing a problem with my FLUKE 199C oscilloscope battery which becomes dead very often and the oscilloscope will not turn on anymore even when the power adapter is connected. Is there any way to make it run on the power adapter regardless of the battery condition.
This unit will not switch on if the batteries are defective or very discharged, even if the power adaptor is connected. The only approved option is to replace the battery pack, a replacement battery pack is available from a number of different suppliers in the UK and USA, but I don't know about suppliers to Lebanon.
Are you sure it's the battery? Have you had a rummage inside to see if there are any bloated caps?
Reply to Fluke 199C in the UK Electrical Forum area at ElectriciansForums.net
I need to handle power failure for my electric strikes in my house. Of course, I can leave the keyed entry on the knobs, but what if I wanted to...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
Hi all, I guess most of you have seen some moving spirals in some fluorescent lamps. Not sure if there's a better description for that, but with...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
