Discuss Fused spur for under counter socket in the DIY Electrical Advice area at ElectriciansForums.net
lou192
Hi, I'm currently looking at moving a socket so it's under the worktop for a washing machine in the kitchen, however I need to be able to switch off the socket. Am I right in thinking that I need to fit a fused spur above the worktop in order to do this?
If it's just one single or double13A socket, then a 20A DP switch can be used instead of a fused spur.
Reactions: DPG
Reply to Fused spur for under counter socket in the DIY Electrical Advice area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
