Discuss gas earth bond in the UK Electrical Forum area at ElectriciansForums.net
Edf came out and used a voltage pen on earth connection and said there was voltage, I've come and tested across gas bond and exposed conductive part no voltage
Have you :-
1. Checked the Ze of the property
2. Checked the continuity of the earth cable from the MET to to earth clamp on the gas pipe.
Yea but what pillick in EDF used a voltage pen instead of a earth loop impedance tester and thats why I asked the questions above . I take it you are a electrician ? and if so have you tested the Ze yet
A voltage pen, time for me to sell me test kit then I that's all you need. Seriously I have a builder friend who said the same to me, when I actually tested it with me megger, low and behold all ok, were edf touting for work or something, sounds like they have been to the bg school of testing
should exchange it for a broad tip felt pen and write "muppet" on his forehead.
Reply to gas earth bond in the UK Electrical Forum area at ElectriciansForums.net
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Iā€™m not working on thisā€¦ not yet anyway, but can someone tell me why thereā€™s a fuse or a link on the earth here? The green wire is bonded to...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
