Search the forum,
Discuss GR10q 16w 4 pin LED replacement in the Lighting Forum area at ElectriciansForums.net
I’m struggling to find how to replace a 16W GR10q bathroom bulb with an LED which is brighter. I’ve read that I need to bypass or remove the ballast but it looks like the 4 pins is actually part of the ballast. Can someone please advise me?
In that case it looks integrated
What I did with all the 16/28 watt fittings in my place was connect the lampholder and lead off a 6" pendant direct to the 230v terminal block
BC led bulb and a galvoband clamp to hold.the lampholder
Bit of a DIY solution but effective for me
I think there's led replacements for the 16w/4 pin
Not sure if you have to remove the ballast
I'd probably replace the entire fitting on a professional job
Didn't look too closely at the link but at £13
I'd probably be looking at changing fittings
I fitted the lampholders and led bulbs in my fittings but that's a DIY job really
Reply to GR10q 16w 4 pin LED replacement in the Lighting Forum area at ElectriciansForums.net
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
