Discuss HDMI from a central point in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
O
Octopus
I'm off to look at a job this morning where the "outline" spec for an extension and along with the normal sparky bits there is requirements for HDMI cables to run from various points back to a central point.
I'm aware that some cables will run up to 15m - anyone got any experiences (good and bad) of doing such an install??
I've used a pre made 15m without issue (caravan). Make sure they are version 1.4. and keep in mind the connectors won't generally fit in 20mm if pulling in later ;) Keep in mind you'll need two cat5/6 per feed if you go that route.
if you're buying pre made leads avoid the ones on fleabay,my mate was having a right problem with his cctv he bought all kinds of new bits THEN he rang me and it was a poxy lead off fleabay.
Reply to HDMI from a central point in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Short version: does code specify a minimum distance from the panel to the first grounding rod, and if so, what is that distance? Long version...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
