Search the forum,
Discuss Heating Controller Being overridden (UK) in the Central Heating Systems area at ElectriciansForums.net
I'm not familiar with that particular actuator. W M H stands for Water, Mid position and Heating. Best to look up the instructions for that actuator to see how to manually operate it.
Sorry missed this earlier, looks like I need to change the actuator, it is quick release so will replace and use a junction box rather than rewire. Thanks for your help.
What sort of junction box do you have in mind? It will need to have clamps to secure the cable, be of adequate IP rating, and be capable of joining several wires.
Much better to do the job properly and change the whole lead back to the wiring centre.
Given that the cable on the MA1 actuator is at best a metre long I don't understand why you are adding a junction box
When you have the actuator off, check that whatever it moves in the valve works smoothly without catching. It's not unknown for debris or scale to build up and limit the travel of the actuator slightly, preventing the switch working as it should.
You can, no doubt, manage a junction box IF you understand the requirements for that junction box, and are able to source a suitable one, which is the reason for my last post.
Hi Brian, thanks for getting back, I've been recommended to get this one,
Regin REGE105-5 way Plug/Socket with Strain Relief​
  1. Regin REGE105-5 way Plug/Socket with Strain Relief
Reply to Heating Controller Being overridden (UK) in the Central Heating Systems area at ElectriciansForums.net
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
I have 2 Mira dual valve vision showers. The remote control.for the Vision model has been discontinued, so I bought a Mira Platinum dual...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
