Discuss Help installing dimmer switch in the DIY Electrical Advice area at ElectriciansForums.net
JayJayPG
Hello,
Looking for some assistance with installing a dimmer switch in my basement. This is the only switch that controls the lights and there are two sets of black/white wires and a ground (see picture below). The capped black/white wires on the top in the picture below does not have any power when I use a tester but I do get power when I use the tester on the black and white wires on the bottom.
I have also provided a picture below of the wiring on the dimmer switch. I thought I was following the instructions correctly when I connected the live black wire to the black wire on the switch, the the white wire to the red wire on the switch, and the ground to the ground. I capped the red/white wire on the back of the switch (not used). When I flipped the breaker on, I got a loud pop and it tripped the breaker switch.
What am I doing wrong? Any help would be greatly appreciated!
Refit the original switch and see if it all functions. I assume the uncapped wires were the original connections to the switch.
There was a remote switch there before that only had two wires (a black wire and a blue wire). Unfortunately I don't remember how it was wired (I could kick myself for not taking a picture of how it was wired before I uninstalled it). That would have been helpful.
What do you mean by remote switch, I see no blue wire there.
Reply to Help installing dimmer switch in the DIY Electrical Advice area at ElectriciansForums.net
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
