C
Chrishands
Hi, where on earth do you run cables in houses with solid concrete floors and solid brick walls with no cavities at all?
Discuss House with concrete floors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
read again, drill ceiling and put in your own battens and then plasterboard.The house doesnt have battened ceelings, the floors and ceeling are solid concrete. no floorboards to lift, i can see how chasing the walls is easy, but how do you deal with running cables in a ceeling. Good strong house, but a nightmare to run cables
You need to read the advice given several times... get other trades to price up the batten and boarding, plastering etc .present them with a quote and await confirmation... this is how it is done, its the trade you chose to do so stop fretting that its nightmare .... it is only so because you haven't done it before...once you done it then it second nature and you get a tick on your experience ladder.
like darkwood says, its easy enough to do.You need to read the advice given several times... get other trades to price up the batten and boarding, plastering etc .present them with a quote and await confirmation... this is how it is done, its the trade you chose to do so stop fretting that its nightmare .... it is only so because you haven't done it before...once you done it then it second nature and you get a tick on your experience ladder.
read again, drill celing and put in your own battens and then plasterboard.
drilling through concrete floors is not a problem
Then the owners will have to look at having the ceilings battened down and boarded then plastered, decorated etc if they want new cabling hidden.
The house may not have battened ceilings or floors but it’s the only way you’ll do this without surface trunking. It’s the customer’s choice, do they want the house to look good after the work or not?
Concrete ceilings are a structural nightmare so don’t even think of chasing in to them. There was a good thread on this subject a while ago, I can’t remember the outcome. I do remember the guy wanted to cut in to the ceiling with a Stihl saw.
core drill/sds drillbit from upstairs down tight against the wall (so its covered by plasterboard and then skirting)
then its just the same as any job, (use a grinder/wall chaser or you will be cursing trying to chase the conctete)
i have never seen a rawl-drill, all battery nowadays or genny if power goes off.I miss the days of smashed knuckles and a rawl-drill when the site had no power, everything by hand and yes you built your arm muscles up pretty quick in them days
Stihl lol , Doesn't bear thinking about does it.The house may not have battened ceilings or floors but it’s the only way you’ll do this without surface trunking. It’s the customer’s choice, do they want the house to look good after the work or not?
Reply to House with concrete floors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
