Discuss House with concrete floors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You need to read the advice given several times... get other trades to price up the batten and boarding, plastering etc .present them with a quote and await confirmation... this is how it is done, its the trade you chose to do so stop fretting that its nightmare .... it is only so because you haven't done it before...once you done it then it second nature and you get a tick on your experience ladder.
Yes that's true, I've just posted another post about gaining more experience.
like darkwood says, its easy enough to do.
core drill/sds drillbit from upstairs down tight against the wall (so its covered by plasterboard and then skirting)
then its just the same as any job, (use a grinder/wall chaser or you will be cursing trying to chase the conctete)
The house doesnt have battened ceelings, the floors and ceeling are solid concrete. no floorboards to lift, i can see how chasing the walls is easy, but how do you deal with running cables in a ceeling. Good strong house, but a nightmare to run cables
read again, drill celing and put in your own battens and then plasterboard.
drilling through concrete floors is not a problem
Then the owners will have to look at having the ceilings battened down and boarded then plastered, decorated etc if they want new cabling hidden.
The house may not have battened ceilings or floors but it’s the only way you’ll do this without surface trunking. It’s the customer’s choice, do they want the house to look good after the work or not?
Concrete ceilings are a structural nightmare so don’t even think of chasing in to them. There was a good thread on this subject a while ago, I can’t remember the outcome. I do remember the guy wanted to cut in to the ceiling with a Stihl saw.
Really, what a plonker lol
I miss the days of smashed knuckles and a rawl-drill when the site had no power, everything by hand and yes you built your arm muscles up pretty quick in them days :)
i have never seen a rawl-drill, all battery nowadays or genny if power goes off.
to be fair in conservatories i stick to hammer and chisel on the dwarf walls and might get the grinder out if they have supplied one of those $hit lounge plates
Stihl lol , Doesn't bear thinking about does it.
Boarding it out will probably work out economically if they insulate the building at the same time. As you and others have said it is the only sensible way to do it
Reply to House with concrete floors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
