Discuss How do I wire this light switch?? in the Lighting Forum area at ElectriciansForums.net
This switch controls 2 outdoor lights. The lights each have 2 live, 2 neutral and 2 earth's plugged into them.
This switch didn't work and when I looked behind it was wired like this!
Anybody know how this should be wired??
Thank you!
Possibly left like that because the switch and wiring was installed some time before the outside lights were fitted, and it's never been fully connected. Still needs investigating and testing, though.
Is there a third light?
If there’s 2 each of live neutral and earth, the last one should only have 1 of each.
Although the switch looks straight forward enough, dead testing would clarify what should go where.
Reply to How do I wire this light switch?? in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
