Discuss How do you split your loads? in the UK Electrical Forum area at ElectriciansForums.net
Stuuk1
After some advice really..
I have the following circuits on the first RCD:
1)Upstairs Lights
2)Downstairs Ring
3)Kitchen Ring
4)Intruder Alarm
And on the second RCD:
1)Downstairs Lights
2)Upstairs Ring
3)Garage
4)Cooker
Would you have done anything differently and if so, why?
Personally I would have swapped the kitchen ring with the garage and the iintruder alarm with the cooker so that the kitchen and downstairs ring are on different RCD's.
Nothing wrong with the way you have done it though.
Nothing wrong with that configuration matey. Maybe an idea to put the intruder alarm on its own RCBO if it is a high integrity fuse board solely to avoid the remote possibility of the battery within the alarm panel draining in the event of a fault from another circuit on the same bank causing the RCD to trip. I tend to advise this with Fridge/Freezer circuits as well.
I will swap the kitchen around then, thanks.
The only reason I ask is because its my first domestic rewire so just not sure of how the guys that do this day in day out would do it.
^^^^^^ I would have done the same with the kitchen ring, so in case you loose the downstairs ring, you will still have some sockets downstairs. (Im assuming the kitchen is downstairs).
Jay
Jay
Yes assuming kitchen downstairs also. Plus also assuming cooker has a socket outlet that's why I suggested swapping the Cooker with the intruder alarm so you have a socket outlet still on in the kitchen.
Reply to How do you split your loads? in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
