Notifiable works
- The installation of a new circuit
- The replacement of a consumer unit
- Any addition or alteration to an existing circuit in a special location
Non- notifiable works
- All other work is considered non-notifiable, namely additions and alterations to existing installations outside special locations, maintenance, replacement and repair work.
Special locations and installations
- A room containing a bathtub or shower
- A room containing a swimming pool or sauna heater.
How will compliance with Part P be enforced?
Failure to comply with the Building Regulations is a criminal offence and local authorities have the power to require the removal or alteration of work that does not comply with the requirements.
[automerge]1595972129[/automerge]
I would just like to acknowledge you
@Brian Taylor for at least asking the right questions and trying to get abreast of what I and others are banging on about. Kudos to you! I would also add that I started training when I was 17 in London around the east end. The working practices and installation equipment has no semblance of familiarity compared to now. The rules and regulations and enforcement have gradually become more and more complex. Because it has been an incremental and gradual change and increase over the years I have managed to keep abreast by continuing professional development (CPD) and so it is not so hard for me. I did it bite by bite so to speak. From where you appear to be it probably may seem a daunting task to get your head around modern requirements. However if you at least take on board the most basic of requirements, notification, you will be batting from a much more secure wicket so to speak.
