Discuss How to measure inductance of transformer in the UK Electrical Forum area at ElectriciansForums.net
If the inductors are in series to get the total value you simply add the individual values together.
So, L tot = L1 + L2 + L3 etc.
Take a look at THIS for a better explanation
Reply to How to measure inductance of transformer in the UK Electrical Forum area at ElectriciansForums.net
Hello, I need to understand whether a DC motor is sturdy or not. The support person told me to measure the armature and field winding resistance...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Assuming that you measure the windings for a power transformer, for example: A-B: 2,258 ohms B-C: 2,262 ohms A-C: 2,250 ohms, how do you...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
