Discuss How to reset E.T.N GEB2080ffg mccb in the The Welcome Forum area at ElectriciansForums.net
W
wei zeng
Hi, Guys
is somebody know how to reset ETN GEB2080fg MCCB, which is stuck in middle of position and can't on or off. the product is out of UK. many thanks for your help.
I did find the technical manual for the device but couldn't find any information about it's operation (admittedly I only skimmed it).
Some devices need to have the actuator moved to the off position before they can be turned back on, but if you can't do that then I'd say there is a good chance it has failed mechanically and should be replaced by a suitably qualified person.
Look carefully for a very small screwhole, insert small screwdriver and turn in or out. This will release the switch. That is my theory. As some MCCB have an adjustor for setting the trip sensitivity. I think this may be the case, obviously not sure as I am not there.
Hi, Vortigern
Many thanks for your theory. It worked for me as well. one small screwdriver inserted one hole and turned out, then the switch worked as normal. Thanks again, other wise it cost £1040 to replace and waiting for two month shipping from states.
regards
Wei
Reply to How to reset E.T.N GEB2080ffg mccb in the The Welcome Forum area at ElectriciansForums.net
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi everyone, Happy Friday! Could someone please point me in the right direction, I’m after the Max Zs for a Bill Talisman TLF633 63A MCCB, I’ve...
Hi, The `power went out throughout the house this afternoon but only to the sockets, the lighting circuits are all fine. I went to the consumer...
