Discuss How would you describe the dangers, when they say it all works in the UK Electrical Forum area at ElectriciansForums.net
Hello everybody! I'm currently completing evening classes at my local college to get my level 2, recently I have been taking a look at the consumer's unit of friends, family (this sounds really sad as I'm typing it) just to gain some more experience of the various types, intake, earthing arrangements etc. Stuff that I don't see in college basically. Well today I saw this at my uncles, who recently had an extension done. That rcbo that is second from the left, is feeding an oven, a microwave, 2 sockets and about 20 recessed lights in the kitchen.
I need some help in explaining why this is dangerous to someone that replys "but it works perfectly"
Well for starters the CU is a right mess, is that blue conductor connected to the Live terminal? you say it's feeding a oven, microwave and some lights, that's bad circuit design, what size is the cable feeding this lot?
Right now, the only cover that it has is the door of the cupboard that it is in, I'm assured that the cover is around somewhere and will be fitted as soon as o_O I did check the oven isolator plate, after switching off main switch, and the wires were in the correct terminals there. I'm not clued up enough to to explain the dangers of the wires being in the incorrect terminals of the rcbo
One worrying thought is 'what else has been wrongly connected'?
There are so many learning points which are going to come out of this for you. How is most functional switching done? How do most/all(?) new socket outlets switch L and N - what order do the contacts make/break and why? What is the potential of the incoming N with respect to terra firma? What happens if the fuse blows in a plug connected to a socket with L and N reversed?
I always explain that getting things to work is very easy , getting stuff to fail elegantly and pose no danger to people or the building is the hard bit. Most sites use ADS to make an installation safe under fault conditions but the installation has to be designed, installed and tested to make sure it does in fact fail nicely, otherwise its really really bad... lol
Optimus these for example:
Re Davesparks #9 - Presumably that circuit is a submain?
Re Plugsandspeaks #13 - Most sites use ADS to make an installation safe under fault conditions
Don’t forget the mixing of manufacturers breakers voids the warranty, whoever fitted them becomes responsible for designing the consumer unit and it can no longer be rated at 16kA as a whole unit because it hasn’t been tested to comply. Naughty Naughty! Another pleb purporting to be an Electrician me thinks or just a cowboy.
The second of the two 32A RCBOS on the right bank shows possible early signs of getting hot. Check the connections to be on the safe side. After the main switch is off obviously.
Reply to How would you describe the dangers, when they say it all works in the UK Electrical Forum area at ElectriciansForums.net
I have recently completed my Level 2 & 3 in Electrical Installations & hold an ECS card, I'm struggling to find a way into the industry I though...
Hi I'm Charlie, I have recently done my 18th edition and got enrolled on night classes for Level 2 C&G Electrical intallations. I currently work...
Afternoon all, Current situation is - Adult learner (I'm 38 in a few weeks) I have my Level 2&3 (obtained last September) started learning at...
