Discuss Humidity settings on fan in the UK Electrical Forum area at ElectriciansForums.net
Good question. Leave as factory settings and be prepared for a revisit in 10 days time. They need to adjust to the environment they are in.
The trouble with cheap humidistat fans is they don't account for the background humidity levels very well. If you get a humid day it will run without the shower being on.
80-90% should generally suffice, on the basis that if someone is in the shower the humidity will be at or close to 100% within a few minutes. Normal humidity levels are up around 70-75% regularly this time of year, so setting the fan to anything less will just set it off when no-one is in the shower, as mentioned above. If you have one o' them there fancy fans which senses a sharp, step change in humidity you could set it lower, say 65-70% I suppose.
My advise... Don't fit the Damn things. Been back repeatedly to so many that I no longer install them.
I would agree 100% with that but some extensions need them and LABC demand them. I always fit an isolation switch so the customer can turn it off too!
Reply to Humidity settings on fan in the UK Electrical Forum area at ElectriciansForums.net
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
