Discuss Hypothetical situation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys
Hypothetical question here
What are the symptoms (if any) of a ring within a ring main?
Is there anything to look out for physically or symptomatically or are they just sonething you stumble across?
Hi guys
Strange readings when doing end to end and figure of 8 tests.
Operationally you are unlikely to notice anything wrong. There would be no obvious symptoms until a conductor overheats, which is of low probability.
Physically a very careful check of the wiring at each socket and a good understanding of how the circuit cables have been run from socket to socket may allow you to identify the cross connection but casual examination would only appear to show spurs.
The defining identification is the readings obtained from the ring final testing as said above.
Reply to Hypothetical situation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
evening everyone . Quick question here I’ve recently took over a job that a friend of mine first fixed it’s a 3 bed semi house rewire. I don’t...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
