Discuss identifying a shed consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
AJ16
This is the consumer unit fitted in my shed, it's very compact and I would like to get another. Does anyone the make and who supplies them?
Why get a new one? if it is working fine and not dangerous then leave as it is and save your money, If you do change it then you will need to get an electrician in to do it as its notifiable to building control under the part p stuff.
So do not take this the wrong way but the question you asked in your post about who makes them and where to buy suggests that you are not either a electrician or 'electrically competent' so to speak so I still suggest getting a local electrician in if you do decide to change it.
I dont want to replace it but I have two other sheds that need one and the existing one is nice and small so I would like get similar ones.
Hi AJ - with my tin hat on - if the sheds are on your residential property then a new CU needs to be metal, as a starter for ten. Here's an IP rated one for example :
T
That looks good, where would I get one? I also found this one. Would it be suitable?
Mini Metal Garage Consumer Unit 63A RCD & 6A, 16A + 32A MCB Amendment 3 | eBay - https://www.ebay.co.uk/itm/Mini-Metal-Garage-Consumer-Unit-63A-RCD-6A-16A-32A-MCB-Amendment-3/291205522915?epid=1255150458&hash=item43cd33a5e3:g:ON8AAOSwU-pXqgc7
plus one for the BG unit.
Reply to identifying a shed consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
I have supply in the garage with its own small consumer unit with a 63a breaker and 1 B6 and 1 B16 breakers. The garage has a ring of sockets...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
