Discuss Inspection Cameras Any Good? in the Electrical Tools and Products area at ElectriciansForums.net
I've recently bought a USB camera , it's bit smaller but the flex is over 3 mtrs, longer ones are available.
The only problem is my oldish Android phone doesn't support OTG and UVC (whatever they are!!) so I use it with a laptop.
I recall I had a similar problem when trying to use the recommended app for the camera so I did a search on the play store for camera apps and tried a few till I found one that worked with the camera
I have this one....
I have taped this camera to the end of my rods and being able to see the hook on the end while grabbing the fish wire has helped a lot over the time I've had it.
Its got a very long reach so can be taped onto a few meters of rod.The picture on the phone is very good and the led lights help locate the wiring no problem.Highly recommeded.Fairly cheap seals the deal for me 🥳
That's the one I have too, except mine is black not yellow!
Cheap enough to not care that it isn't used much. Good enough that when I want a camera it usually saves the day.
I tape mine onto rods too.
Reply to Inspection Cameras Any Good? in the Electrical Tools and Products area at ElectriciansForums.net
I have a renault trafic. I am not good at reversing, I bump things. My reversing sensors have packed up so i am bumping more things than usual. I...
Hello, we're looking at relocating the CU fairly urgently for a small business (retail shop) and came across this service head. Obviously need to...
4K
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
