Discuss Inverter unbalanced load in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
spionkop
When trying to match an inverter to a PV array I come across figures for 'Unbalanced Load'.
What causes an unbalanced load and how critical is this.
Different number of panels on each string. For example a 11 panel system on two strings. I have always avoided unbalanced and reverted to a different inverter.
Thanks for that guys. I can see that strings with different numbers or sizes can give an unbalanced load but when I put eg. three strings of equal size capacity and manufacture into my software it shows an unbalanced load of 3.3kVA and I just wondered how this could be and if it is acceptable?
I have know manufactures software to allow three strings but their inverter only has two? What is it you are using and on what panels & inverter. I can run it through PV-sol if you give the details. Number of, make and model of panels and inverter make and model? I wouldn't do your design just see what it throws out.
Hi MarkC.
I am planning a 6.6kWp array using Kyocera KD185GH-2PU panels which conveniently split into three strings of 12 panels, through a Fronius IG Plus 70-2 inverter.
Look forward to your findings.
Hi MarkC.
Hi Spinokop
18 Panels on 2 Strings produce a better result on the same inverter. See pic's
Reply to Inverter unbalanced load in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
So my friend's inverter is not working and fault code says - bus voltage unbalanced. Has anyone come across with something like that? Inverter is...
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
