Discuss IT Equipment & Other Sensitive Equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
S
stules2905
Fairly new to PAT Testing. Been qualified for a while but not done any!
Been asked to carry out all the PAT testing in the office of our company.
Fairly mythed as to the testing of IT equipment and sensitive stuff such as monitors, printers, fax machines and the like.
I am using a Fluke 6200. It does not have an option to decrease the IR voltage and was wondering whether to leave it and just do the 200mA bond.
Got some monitors to test and didn't know whether they were susceptible to damage? Not only ones with IEC leads but also ones with DC Power straight from the plug.
Also like I said, fax machines, boosters, printers, franking machines. If anyone can shed any light on this it would be great!!
Cheers
Stu
I can't help thinking PAT testing IT equipment that's classII beyond a visual check is likely to cause more heartache than it's worth. Even if you connect the L+N together an test using 250v range, the day you come across a piece of equipment with an earth referenced comms system you're still probably going to blow the comms card with a N-E voltage of anything over 30v or so.
If you check your tester you will find that it shorts out the L & N pins and conducts the test to earth. Therefore it doesn't damage anything.
Plug-in PSUs can only be inspected visually. the IT equipment they feed is selv, so there again, visual. afaik, PAT teaters do the IR by linking L-N and testing to E, so should not damage the equipment. and the earth bond test should be carried out using the 100mA setting.
RS232 comms with internal earth referencing possibly won't survive an IR test to earth even with the L+N shorted during the test.
So you could test all of the things I've mentioned above with a 500vDC IR test as long as the bond was done at a low current??
Reply to IT Equipment & Other Sensitive Equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
  • Locked
Hi all I am in an industrial unit and the 100mA RCCB keeps tripping. They use it as the main switch inside of the unit's distribution board. The...
6K
