Discuss LED PIR flood with override in the UK Electrical Forum area at ElectriciansForums.net
I've only ever seen LED floods pre flexed with 3 core Lee, sometimes 2 core for Class 2 versions. It's an annoyance when they don't give you a proper override wiring option, I'll sometimes use a seperate PIR and you can also run more than one light from it or interlink with more PIRs if required.
I have seen several led lights with built in pir that do just what you want.
often they have a 3 core flex pre made into the enclosure but if you look inside there is a 4 way terminal block with L N E + sw L inside so you can link them together.
I have not got the makes and models to hand but it is common and you often don't know its there without reading the instructions.
P.s. I know we don't read them much but there is often something usefull in there.
Well why don't they fit the correct flex in the first place where that's been designed in, half baked manufacturing !
I half agree,
many diy peeps will be confused about the 4th wire and either just chop it off or leave it floating
and for 90% of installs its not required.
for most of my jobs, I have to replace the flex as it is too short anyway.
who wants a junction box within a foot (300mm to the young ones) of the light when most of the time within 6ft there is somewhere to wire it into.
was thinking of this one really, have used before and seem ok.
wont let me post a link ... but first one in led pir
[automerge]1567155235[/automerge]
tlc-direct.co.uk/Products/LTFL10PIRCW.html
stick www in front , it wont let me post a link
That Timeguard one has the most comprehensive instructions I've ever seen! usually it says "To mains the be connection doing, at best for it, you can." With a crappy wee diagram that's illegible.
This Timeguard one even shows you which way to turn the screwdriver to tighten the mounting screws! (5.7) and you also get a Knob Adjuster, 8.3...
Any one have any recommendations? Don’t really want one where you have to flick on and off multiple times to override.
I'm a big fan of Brackenheath, Lee. At the top end, price wise, but they do them with a good microwave sensor....about a 300 degree pick up.
Philips do a new one with remote control, you can set all the settings via remote and manually over ride it from remote too. can adjust sensitivity, lux etc and brightness too. they have it kew electrical was about £30. a few weeks back
philips remote control pir light
Reply to LED PIR flood with override in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
I want to buy two of the above for my property. I am on a budget. The property can get battered by driving rain, finding an outdoor LED flood...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
I've a light fitting that's controlled from a Whitecroft absence detector PIR and a wall switch. The way it works, is the Retractive wall switch...
I've a money-no-object customer who needs three flood/uplights replaced. Any recommendations for a really solid, well-built unit that comes with a...
