Discuss little help with volt drop calc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
jon4381
Hi everyone just a little confused,when calculating volt drop using table 4Ab do you measure the voltage of the installation and use that value to calculate or do you just use the 230 volt value
not sure what voltage has got to do with calc for volts drop
Hi if you are calculating it the ohms law way (which I prefair to be honest) then yes for a single phase you would use 230 as you nominal voltage it may be a bit higher or lower if u tested the actual voltage but you would still just use 230v for the calculation
I think he means to find out the maximum volt drop allowed for instance I think maximum volt drop allowed is 4% so 230 x 4 divided by 100 is 9.2 volts so maximum volt drop would be 9.2 volts.
Well that what I think he means
Reply to little help with volt drop calc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
Hello, New trainee electrician so sorry if this is a dumb question I feel confident with calculating the volt drop for a ring and radial circuit...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
