Discuss Load and heat in the UK Electrical Forum area at ElectriciansForums.net
take a load of 10kW @ 240V for example.
P=I V so I = P/V = 10,000/240 = 41.667A
from that using ohm's law, R = V/I = 5.76 ohms
now assume that V =230V
I =V/R, so I= 230/5.76 = 39.93A
so @ 230V P = VI = 9.184kW.
Thanks Tel for a more helpful reply than many have been. Daz
there will be a very slight variation on that as with the slightly higher current @ 240V, the cable will be very slightly warmer, thus having a very slightly higher resistance, but the difference is too small to be considered.
Reply to Load and heat in the UK Electrical Forum area at ElectriciansForums.net
Hello All I was hoping for some advice. We have a microwave and recently after cleaning, as soon as the microwave was plugged in, a loud humming...
Do you install new heating systems? Ever had a missing cable run between a boiler and a pump? Using MAINSLINK - the pump overrun solution - you...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
