Discuss loop resistance & capacitance voltage transformers in the Industrial Electricians' Talk area at ElectriciansForums.net
speedtronic
1. To measure loop resistance of small motors rated in KVA, we simply use a multimeter to get required results while for large motors/equipment rated in MVA we have to use a test set through which we apply some current & get the results. Why doesn't multimeter work there?
2. What is the purpose of capacitors in capacitance voltage transformers?
Moreover, what is the difference between a PT & CVT?
Reply to loop resistance & capacitance voltage transformers in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have an original 250w glow plug in my 8yr old pellet boiler that's used to light the pellets during the start up phase on my boiler. The boiler...
I have a pressure washer that I got as part of "a good deal", actually an exceedingly good deal as I later found out. I've had it a while, I guess...
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
