dc99
Hello all
I'm confused about Part L and the light fittings required for a domestic loft extension.
I'm aware that a certain number of the fittings need to be low-energy and compliant with Part L in that respect. I can find plenty of information on what a particular lamp needs to be in order to comply in terms of lumens/watt and can see on TLC Direct, etc. plenty of lamps that I could use.
However, my confusion is around the light fittings themselves, which I believe need to be such that they can't have non-compliant lamps inserted. Unfortunately what I cannot find anywhere is the definition of what exactly a compliant light fitting standard is.
So, for example, I can find plenty of compliant LED GU10 lamps, but I'm concerned that if I fit those, the building inspector will fail it because, while the lamps are compliant, I could in theory plug non-compliant GU10 lamps into the fitting (i.e. compliant lamps but non-compliant fittings).
Can anyone shed any light on this ?
Darren
Darren
