Discuss main fuse in the Australia area at ElectriciansForums.net
F
fire
i becam Part P registered 8 months ago, need to change a consumer unit do i need to call the distributor to pull the fuse as there is no isolator?
has the seal not fallen off? seroiusly though, depends on who thre distributor is. usually, if you let them know you've got to pull it, they will call when you have done and re-seal.
you could phone them and ask what their procedure is.
Electricity at works act would supercede any supply authorities quirks on this one. You are legally obligated to isolate the supply before you work on it. If you have no other means of isolation then pull the fuse under no load conditions of course. Your safety and others take priority, so stuff em.
a bit of common sense there, always overrides the jobsworths of this world, i say.
just pull it..........................who really cares, as long as u re-seal it than u can justify pulling it. work safe, live longer.............thats my opinion, and i will always cut, pull and re-seal if required. bugger the DNO, my life is more important, they will not prosecute, and if they ever try to i will be able to justify why i did it quoting the EAWR regs!
happy fuse pulling bud!!!!
I doubt they actually mind us pulling the fuses, they just won't say that you can, so if there is an accident they can say that you shouldn't have been touching it in the first place!
Apparently there was a sparky killed by a fuse carrier that broke up in his hand, I presume that it was ancient or damaged but if in doubt glove-up.
You can get the DNO out to fit an isolator in the tails but you will probably be waiting several weeks and it will probably cost you. (about £60 quid I think. Not done it for a long time, I just pull the fuse like everyone else I know)
had phoned eon and they said they can take upto 2 weeks to come out just to pull the fuse and another week or so to put it back!!
Reply to main fuse in the Australia area at ElectriciansForums.net
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi all, any recommendations for neat and complaint ways to "house" a new supply -- the main electrical fuse, cut out, meter etc that on our house...
