A
andyp69
Hi Guys
My first post here....so hello all.
I have very recently looked at the electrics in a flat with respect to doing at PIR for the owner before he lets it out.
I did not have access to the meter cupboard which is on a differnt floor to the flat. (I have requested access but so far have not been able to get it).
The main incoming cable from the meter into the CU in the flat is something i've never seen before.
The brown live cable is a normal single cable as i'd expect to see. The blue neutral seems to be a lot of individual small csa cables all connected into the main neutral on the isolator switch. The total csa in relation to the single live looks to be ok. Live is 16mm. The individual neutrals look very similar in total to 16mm.
Everything else in the CU looks ok. The External Earth loop reading on the mains is good. (0.26ohms).
Is this sort of main incoming neutral acceptable or should it be a single cable.
There are quite a few other issues with the install which are internal to the flat. With the main supply being external - if the supply cable is an issue then i guess it may be down to the owner of the buiding.
Not really sure what to put on the PIR thou.
Any assistance would be greatly appreciated.
