Discuss Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
When the new reg for metal CU’s came in, Certsure web in air vid, with that Darren Standforth what’s his name, said the idea behind the change was to remove a source of fuel (i.e. the plastic enclosure) from a fire. Then they changed the reasoning to containing a fire.
From that op pic, think the former was better reasoning, if at all.
The new reg is for CUs constructed from noncombustible materials, just so happens that metal is noncombustible, or in a noncombustible enclosure.
I guess a metal enclosure both removes the fuel and the oxygen from the fire equation, but I'm fairly sure the core principles behind a metal enclosure is to remove oxygen. There will always be fuel in the way of plastic casings for breakers and cable insulation.
OP's pic is kind of a moot point as the fire started outside the enclosure
Yeah but the enclosure cover has been consumed by the fire, whereas the cabling & switchgear has to, but to a lessor extent. I recall reading somewhere, switchgear, the MCBs etc, are manufacturered from a different grand of ‘plastic’.
Of course a metal enclosure is suppose to limit the spread of fire, why do you think people call them fire rated? As Midwest said, there is a reason we stopped using plastic.
The intent of regulation 421.1.201 is considered to be, as far as is reasonably practicable, to contain any fire within the enclosure and to minimise flames from escaping, caused mainly as a result of poorly installed connections
Dunno if you've watched this vid? Whilst they don't suggest metal CU's are supposed to be fireproof, nor remove source of fuel, and its bit old guidance by now, still interesting vid about metal CU's back then. Sound needs adjusting at beginning.
Fire protection: panel discussion 1 at the ELEX show in Harrogate - https://electrical.------.org/wiring-matters/issues/56/fire-protection-panel-discussion-1-at-the-elex-show-in-harrogate/
New posts
Reply to Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
  • Locked
5K
