Discuss mid position valve issue in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
poheZ
HI all
I have a problem with a mid position valve that wont move into the heating only position after being in the mid position (i.e. when the water and heating are calling, the water turns off and the valve wont move to the heating only position). The wiring is correct and i have verified it against a y plan wiring diagram (unless of course i am wrong), i wonder if anyone has had this problem? Anything that may cause it (apart from a faulty valve)? I take it all mid position valves are wired the same?
99% of the same faults i have been to are a faulty mid position valve
99% of the time you can just replace the head or the motor inside, i always replace the head nowadays
You can test that you have 230v returned from the room stat back to the valve/wiring center and if so then the valve is faulty
In very rare circumstances the ball become detached in the valve and you would then need a plumber to change the mid position valve body
Quick edit
let me know what valve it is as some heads can not be replaced and undoing the screw lets the water out hehe
as long as you have the hot water off connection ie; from the cylinder stat and the time clock you should be ok. try a replacement head on the valve
Reply to mid position valve issue in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hello I have a central heating system, with a Y plan layout. The neon indicator on the thermostat seems to be sometimes dimly lit / flickering...
