Discuss Minor Works Test/Certificate cost? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
cairns
Hi there, I'm running some downlighters off an existing feed. Someone I know said I would need a minor works test/certificate, is this true? What does it involve? How much would one of these usually cost?
Cheers:)
are you a sparky or just doing this as a diy/ favour? also, if these downlights are in a kitchen/bathroom they are notifiable to building control.
If u was doing this work in someone elses house as an electrician you would issue a minor works certificate. Look one up on net or look in On Site Guide / GN3 and look at what it entails . It lists all tests which you need to carry out after installing the new downlights and if results comply then you issue the Minor Works Certificate. HTH
Reply to Minor Works Test/Certificate cost? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
