B
brizospark
Hi All,
I am working in a property where there is a system boiler which is controlled via a standard timed programmer however the client has asked that there is to be a motorised zone valve installed at lounge radiators, with a thermostat in the lounge, so that the temperature of this room is controlled spearately from the rest of the system.
Can any of you guys put me the right way regarding the connections that would be required for this.
I have installed 2 x 3 core and earths to the zone valve from the boiler and 1 x 3 core and earth from thermostat position to boiler, to cover all bases.
The zone valve being installed is a honeywell version, the type that has the 5 core pre-flexed cable attached
