Discuss Multiple Virgin telephone points in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi All,
I have recently rewired a 4 bedroom house in which i have installed 4 telephone points throughout the house as requested by the client. i have wired 3 slaves from the point Where BT would bring in their cable to the master. The problem i have is that the customer as now went for virgin. She has phoned complaining that the virgin installer won't or can't connect to my Master phone point position therefor the slaves wont work. I know Virgin have there own telephone line but my question is ,can i do something to connect their phone point on hub to the slave points i have wired?
Thanks for any input
Usually the provider will install the master socket. The Virgin one ought to be the same as a BT one, but wherever they decided it was easiest/cheapest to put it in.
You should be able to attach your slave ones to what they have put in.
You don't need a Master socket with VIrgin, they don't use a separate phone line.
Phone, Broadband and T.V all comes in down a single coax.
Just re-read, you haven't fitted a Master, it's Virgin that won't connect into your sockets?
Virgin just leave an adapter from U.S style in the back of the Hub, to U.K style as pic
My cable has both coax for the CATV/internet, and a separate POTS line for the phone.
Not sure if they still do that though. Also in some areas they are basically ADSL style phone lines for internet as for BT, etc., and not coax.
I have BT fibre to property, and the hub has a standard 'phone jack (431?) on it. I used a short lead, prewired with a plug, to a 4W IDC junction box, straight to the 'phone cable to the slaves all over the house. No master sockets involved.
Yes they wont connect to the ones i wired. Is that just a lead from the hub into the first telephone point?
Is virgin using the BT Fibre? sorry if i'm being daft. What type of lead do i connect from Virgin Hub to first Slave point ? thanks
Should be the same plug as on a standard 'phone, via an adaptor, looking at snowhead's pic. I used a plug and part of the lead cut from an old 'phone and joined it to the house's phone cable using a small IDC junction box that I happened to have. Was intended for cat5 cable, IIRC.
BT fibre and Virgin fibre are different things, but booth work in the same way - fibre optic cable to your house into a modem.
Ok,
Instructions on hwow to bodge are as follows:
1. Advise customer that if you are using the hub as source of phone signal then there may be ringing problems if more that one phone is plugged in.
2. Purchase BT to RJ11 Line Cords, BT to RJ11 Cables 2m-10m Lengths - https://www.bcedirect.co.uk/products/bt-to-rj11-line-cords-bt-to-rj11-cables-2m-10m-lengths
3. Purchase an RJ11 socket for above
4. Connect the wires in the cable 2. to pins 2 and 5 of the BT socket
5. Ensure that any connections to external BT plant has been removed
Ok,
You need to connect pin 3 as well, or you want get incoming ring.
The ring signal is generated inside the modem, so a master socket isn't required. I haven't tried it, but I doubt if there's a ring signal on 2 and 5 out of the modem.
If I'm wrong, and there still is a AC ring signal superimposed on 2 and 5, then the cap. in the master would still couple it to 3.
B.T wouldn't have connected the house extension sockets unless they were previously fitted by B.T.
Yes, I fitted a socket next to where the hub is and I made up a short double ended B.T plug to B.T plug lead. (431a to 431a)
You can buy them, search BT male to BT male.
Reply to Multiple Virgin telephone points in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
Hi Everyone, I have what looks like a BT telephone line distribution box which was installed over 30 years ago (residential). Photos of it are...
