CK Tools :) The professionals choice when it comes to Electrical Tools
Advertisement - Content continues below
Discuss New Wylex consumer units in the Electrical Tools and Products area at ElectriciansForums.net
E
EasyFox
The new offerings from Wylex for 17th edition installations. Incase you are interested.
Hope the link works not to hot with pic's
Instyle LED Lighting Specialists UK
T
TonyM58
  • #2
EasyFox
cheers for that
i am just starting to do my prep for teaching the 17th edition and the update, so this is good info for my powerpoint
Ta
G
Girlyspark
  • #3
Really interesting - thanks for that.
T
TonyM58
  • #4
EasyFox
do you have a link so i can go the website where you got these from please?
regards
Tony
E
EasyFox
  • #5
No problem mate.
Contact Form
In the additional comments box I asked for any infomation & litrature on consumer units that will meet the new 17th edition wiring regulations.
I have been told that the wylex units although in manufacture & having a parts number, do not as yet have a recommended retail price as they are so new.
Gaz
M
moffatp
  • #6
I bought a consumer unit from Screwfix in May (pre 17th edition).
The new 17th editin seems identical (checked the part numbers) except that there is a second RCD in it and the wiring is slightly different to accomodate the second RCD.
Can I convert the older unit to 17th edition by adding a second RCD?
E
EasyFox
  • #7
Two ways you can do it
  1. on non rcd side of cu, change all mcb's for rcbo's (sit down when pricing it up)
  2. See if Wylex do a conversion kit (not sure they do), this will enable you to install a second rcd in parallel with other rcd to mainswitch. This method you will loose 2x ways on the cu.
M
moffatp
  • #8
Thanks for your response - but what I was suggesting was to fit a second RCD and wire the MCB via it as per thr other protected RCD side of the CU, this is exactly what the new CU does. with exactly the same parts. This would be cheaper than fitting RCBO as the RCD is approx £35, you would of course loose a couple of MCB spaces.
Test Meter - Forum Sponsors since 2007!
Reply to New Wylex consumer units in the Electrical Tools and Products area at ElectriciansForums.net
uHeat Banner - Forum Discount Available
Top Bottom
