Search the forum,
Discuss No access to low voltage downlights transformers on EICR in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Evening Guys, got a house to do an EICR on and there is no access to the 3 plating/transformers on 12V downlights in 4 different rooms. Everything looks nice and pretty and shiny but its all been boxed in. the cut out diameters are to small to pull the transformers down so am unable to take any readings. Im not sure what to code this! Any ideas
think he's concerned about IR testing. only thing you can do there is link L to N and IR from these to E ( on the LV side, of course).
Reply to No access to low voltage downlights transformers on EICR in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have undercabinet lights that are low voltage. They work xenon pucks just fine. I want to convert to low voltage LEDS. Supposedly these are...
Currently I have 4 small low voltage transformers connected to 4 circuits of low voltage yard lights. They are under my deck, and I turn then on...
I'm trying to replace 4 inset downlights with surface mounted ones: Phoebe LED, Atlanta Universal Downlight 6.5W/3000K, chosen as they'll...
