Discuss No continuity of neutral conductor in the UK Electrical Forum area at ElectriciansForums.net
I sometimes do similar if house is unoccupied.I tend to leave one leg out of the board, switch the circuit back on, (with all appliances unplugged on circuit of course) then walk around with my martindale until it beeps in a grumpy fashion. Make a note of grumpy sockets, then isolate, swap legs in the breaker and repeat, see which ones now have N again and can then ascertain where the problem area is using mainly my ears?
Someone has moved the circuit off the rcd cover and moved it on to a mcb on its own so it doesn't trip the rcd ( due to the imbalance)
Due to this im going to back heel it
The fact of the matter is. Someone has moved the circuit off the rcd cover and moved it on to a mcb on its own so it doesn't trip the rcd ( due to the imbalance)
Due to this im going to back heel it.
This tells me someone has tried to fix it but couldn't so have came up with this as a solution.
Just call me Holmes.
Can't help but think that it will be a missed opportunity for you walking away when there is some valuable learning to be had finding this fault it is admitting defeat before you have even started, the previous guy failed so go out and do better than him and find the faultThe fact of the matter is. Someone has moved the circuit off the rcd cover and moved it on to a mcb on its own so it doesn't trip the rcd ( due to the imbalance)
Wasn't he defective.... oops sorry detective??Just call me Holmes.
Not the best attitude to have...Especially not as a trainee!
What imbalance? Loss of neutral continuity on a ring won't cause an imbalance. However the problem that has caused the break in the neutral might have caused an earth fault as well (e.g. nail through cable) or the two might be completely unrelated. Indeed, someone playing the detective looking for an intermittent earth fault might have left the neutral cable out of the terminal by accident. Keep an open mind and test systematically.
I agree i should have maybe tried fixing it myself, but you didn't/havent seen the property and I've got so much going on. In future I'm planning on getting stuck into the fault finding, hence why this post. Building up my knowledge in the meantime. No doubt someone on this will take a pop, but whatever.Can't help but think that it will be a missed opportunity for you walking away when there is some valuable learning to be had finding this fault it is admitting defeat before you have even started, the previous guy failed so go out and do better than him and find the fault
A customer you walk away from is a lost customer for the future and looking at the bigger picture someone who won't recommend you to others in a positive wayI agree i should have maybe tried fixing it myself, but you didn't/havent seen the property and I've got so much going on. In future I'm planning on getting stuck into the fault finding, hence why this post. Building up my knowledge in the meantime. No doubt someone on this will take a pop, but whatever.
That's your negative view on the situation, I spoke with the customer today. Once the fault is repaired he wants me to check it then install some smokers. OK goodnight over and out.A customer you walk away from is a lost customer for the future and looking at the bigger picture someone who won't recommend you to others in a positive way
I'm not repairing the fault, omg. Ye I've 2 sparky mates. Your in the wrong job mate, you should be in the auld bill.Who is repairing the fault? Are you working alongside someone?
I'm fine mate.You're very touchy about things. What's up?
I'm fine mate.
Reply to No continuity of neutral conductor in the UK Electrical Forum area at ElectriciansForums.net
