Discuss Non-Electrician: Switch Fused Connection Unit Light Not Working in the The Welcome Forum area at ElectriciansForums.net
Full rewire and Cu unit change I reckon......
Did the status light ever come on and off with the switch before? If so it's just the light thats gone in it and everything will still work as it should. As long as the switch still isolates the appliance, and you do not care for the status light, all is good. If you would like to have the light back, you will need to have the switched unit changed.
You’ll be fine on here Phil!Thanks everyone (including the jokers - good thing you put in the emojis or I'd have taken you seriously). Much appreciated.
Reply to Non-Electrician: Switch Fused Connection Unit Light Not Working in the The Welcome Forum area at ElectriciansForums.net
