Discuss Non-Electrician: Switch Fused Connection Unit Light Not Working in the The Welcome Forum area at ElectriciansForums.net
The neon light on my flat-plate/switched fused connection unit doesn't come on when I use the washing machine. The machine still works - but does the fact that the light doesn't come on mean something is wrong? Do I need to get an electrician in?
Did the status light ever come on and off with the switch before? If so it's just the light thats gone in it and everything will still work as it should. As long as the switch still isolates the appliance, and you do not care for the status light, all is good. If you would like to have the light back, you will need to have the switched unit changed.
did it used to work before? could be just a blown neon, or 1 of the connections ( the neon is connected to the output terminals with pretty thin fragile wire).short of pulling the FCU off and checking, nothing to worry about IMHO.
Yes. There’s something wrong.... the light doesn’t work.
Probably nothing wrong at all, but it would be worth having it checked by an electrician.
If the wire to the light is loose, there may be another loose wire.
Funny things neons......never quite know what you will uncover....ha ha ha
Sorry OP follow advice above,except the bit about the hammer DO NOT hit it with a hammer
Thanks everyone (including the jokers - good thing you put in the emojis or I'd have taken you seriously). Much appreciated.
Reply to Non-Electrician: Switch Fused Connection Unit Light Not Working in the The Welcome Forum area at ElectriciansForums.net
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
Hi all, hoping someone might be able to help a little, we got our daughter a renault twizy, but the headlights do not work. The side lights...
